Obd0-obd1 WIRING HELP! swap help!!!
I recently dropped a d16y8 into my 1991 Honda crx si!
I'm going to be running a p28 ecu and I have the jumper harness for the ecu and distributor.
Was wondering what tips or suggestions you all have for wiring everything
The jumper wires are typically for: additional 3 wires for 02, VTEC solenoid, VTEC pressure switch, IABS (not needed in your case), knock sensor (not needed), service check engine connector, etc like this
http://www.locashracing.com/instructions/OBD0-OBD1.pdf
cantbetouched24
Mar 20, 2009 12:38 PM
hondaeg8
Jun 21, 2004 12:00 AM
