Engine rebuild choice - What's the difference between the d15b and d15b2?
Old Feb 16, 2016 | 11:38 AM
913drhatch's Avatar
Default Engine rebuild choice - What's the difference between the d15b and d15b2?
Hello I've recently blown my d15b I have a d15b2 that smoked I don't know if there is any difference between the two if I'm going to rebuild would the d15 b be any better than the b2?
Old Feb 17, 2016 | 11:31 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: Engine rebuild choice - What's the difference between the d15b and d15b2?
There are three different versions of the D15B engine. The HP is either 103 or 130 depending on if it has VTEC. The D15B2 is 92hp.
You can visit wiki for more detailed information about each engine.
https://en.m.wikipedia.org/wiki/Honda_D_engine
Old Feb 17, 2016 | 02:38 PM
SidPM-EG6's Avatar
d15b is JDM .d15b2 is eudm or usdm or wtvr other market..
All 4 digit engine codes are JDM ... and usually JDM engines have higher horsepower and compression ratios than other markets models
Old Feb 17, 2016 | 02:47 PM
NotARaCist's Avatar
I never narc'd on nobody!
No, four digit engine codes are not always JDM. Yet another rumor that needs to die.
Old Feb 17, 2016 | 06:12 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Actually I believe there are 4 versions of the JDM D15B. Dual Carb, Dual vtec (3 stage), non-vtec and vtec (2 stage).
Of note, I know with some certainty that the non vtec and the dual carb has the same bottom end as the D15B2, small rod, small journal motor.
I believe the vtec D15B has the larger rod and journals like the D16Z6.
I am not sure of the bottom end of the Dual vtec model but I suspect it's superior to the D15B2 bottom end.
Old Feb 18, 2016 | 03:32 AM
hondur's Avatar
Dur Da Dur
5 Year Member
The dual vtec / three stage motor is rumored to have the same bearings and what not as the z6. I've never seen pictures of anyone mic'ing it or anything like that though.
Shaan
Honda CR-V & Element
Mar 25, 2018 03:39 PM
crovard
Apr 12, 2016 09:12 PM
randommiker
Apr 27, 2007 07:55 PM
Ben_si
Oct 7, 2005 06:07 AM
