ITR ABS sensor issue
Hey guys,
I recently snapped the metal sensor piece off of the front right ABS wheel sensor on my 2001 ITR. I went online to replace it, and found that only the front left and rear ABS wheel sensors were available. My mechanic couldn't find anything either, and tried a non type-R sensor, but it didn't work. I noticed that the metal piece on the end of the ITR sensor, the part that detects the bumps in the ABS ring on the CV joint, is a lot longer than on other non-ITR sensors. Has anyone else had problems finding this part? Could I make a front left sensor work?
Thanks for any advice
I've run in to part # issues before and get my answers from, bernardiparts dot com
PartsSalesTeam@BernardiAutoGroup.com
If you want to call instead, 800-924-1884
Spoke to them, apparently Honda/Acura don't carry it, and there isn't any aftermarket support for it. Talked to an Acura parts guy, going to try the sensor off of an LS. Hope it works!
