2000 Accord v6 engine auto-revving (non-stop revving) in all gears.
Weird problem occurred today, need some help/advice before I go take it to the local Honda dealer/repair. I'm not a car person whatsoever but I'm aware of these problems. This is a 2000 V6 Accord with ~208k+ miles, oil/fluid changed last month.
Background problems I'm aware of:
-May* have a coolant leak
-Previous odd idling problems but no where as severe now
-Issue likely related to "vapor lock"? IACV valve issues?
The current issue now is on startup my car automatically revs past 1.5-2 RPMs and goes down only to rev back up. It's nonstop revving every 2 seconds in every gear. Park, Neutral, Reverse, and Drive. I'm fighting it when it's in reverse or drive because it's always giving a little power even when on the break.
No idea what happened, it happened randomly on startup today after being driven around for a bit and now the problem persists. It's definitely not safe to drive and need attention ASAP. Just want some feedback before I call the Honda service repair shop in the morning.
I have had this to my old Prelude when the cooling system was low. I have also had it happen when there was a vacuum leak, but that only happened during idle. Another time I have had this issue was when my Idle Air Control Valve was loose and dirty.
I have a feeling the cooling system issue is the culprit, but check all 3. Regardless, that cooling system issue needs to be fixed. Make sure it is bled nicely, too.
MEngineer
Jul 31, 2016 04:58 AM
justtmark
Sep 22, 2013 06:23 PM
Jaysun
Oct 6, 2006 09:58 PM
