Engine mounts for b series eg
Old Feb 12, 2016 | 06:26 PM
gostlyman2's Avatar
Default Engine mounts for b series eg
I have a 1994 honda civic hatchback cx and I'm swapping the engine for a b18c. I was looking at engine mounts and wasn't sure what the difference between hasport motor mounts and innovative motor mounts was besides around $100. I also wasn't sure if I needed 3 bolt or 2 bolt. Thanks in advance.
Old Feb 12, 2016 | 06:37 PM
tony_2018's Avatar
Fish Twig
Default Re: Engine mounts for b series eg
Do you not have the motor in front of you?
Old Feb 12, 2016 | 06:48 PM
NotARaCist's Avatar
I never narc'd on nobody!
2 bolt or 3 bolt all depends on what mount you have installed on the driver side (timing belt side) of the motor itself. Sometimes it's a 2 bolt, sometimes it's a 3 bolt. Look at what you have, and boom, that's what you need. The difference between Hasport and Innovative is brand marketing, and mount appearance. Hasport is more well known, is shiny and ****, and offers fun coatings and **** for more money. Innovative (at least, their $100 cheaper option) are black steel, done, end of story. Both are good. Yonaka is also a good option (and what I'm using for my B swap), if you want cheap cheap.
Old Feb 13, 2016 | 07:24 AM
gostlyman2's Avatar
Would these be the ones I want It won't let me chose 2 bolt or 3 bolt though....
Honda B Series into Honda Civic/Integra/Del Sol Motor Mount kit
Old Feb 13, 2016 | 10:16 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Look at the bolts on the engine you're swapping in.
Two bolt mount;
Three bolt mount;
Once you've determined what you have, buy the set that's appropriate. Since you haven't told us or posted a pic of your bolt pattern we can't tell you if those are the correct mounts.
eH.
Old Feb 13, 2016 | 10:06 PM
NotARaCist's Avatar
They have two different listings. Call them to get exactly what you need.
Old Feb 15, 2016 | 10:01 AM
OxDseries's Avatar
Question... Any actual difference on 2 or 3 bolts... meaning like 3 is better than 2... or they are just for weight purposes...
Old Feb 15, 2016 | 04:40 PM
NotARaCist's Avatar
Honda decided to make a 2 and a 3 post mount. That's all there is to it.
MIEj1
Feb 25, 2013 06:07 PM
SnailTypeR
Jun 16, 2010 03:02 AM
gosu08
Feb 6, 2010 04:50 PM
Kusai.Nihonjin.Desu
Apr 10, 2005 08:52 AM
