91 Honda Civic Si Not Starting
I have a 91 Civic Si that stalled out while driving on the freeway a few days ago. The engine will turn over but won't start.
First thing I checked was for spark and there was none. So I replaced the ignition coil with a working one. Still nothing, no start, and no spark. So I ordered a new distributor online and still nothing. The fuel pump primes and the CEL comes on for a few seconds then shuts off when the key is in the ON position. I have also resoldered the main relay with no luck as well. The ignition switch is less than 6 months old. I'm going to switch out the ignition switch with an old one I have laying around just to eliminate it. The timing belt looks fine, I have the top timing belt cover off and can visually see that it's not shredded.
Any other idea's on what to look for? I have googled and most threads lead to a bad ignition coil, igniter, or bad main relay. The car is stock besides a DC header that came with the car when I bought it two years ago.
hatchnation
Nov 12, 2014 02:34 AM
carguy717
Jul 18, 2008 06:57 AM
Mark D. Surface
Jan 31, 2005 12:15 PM
