OBD0 to OBD1 jumper
Old Feb 11, 2016 | 01:38 PM
shopa's Avatar
Default OBD0 to OBD1 jumper
Hey, need some help with future swap...
Have CRX with factory B16A1 vtec engine, I guess SiR model in the US, which is obd0.
I'm going to put B16A2 engine from civic eg6 which is obd1. Engine is full swap - ecu,shafts, loom, dizzy, sensors and hydro gearbox.
Will not use nothing from my stock B16A1 engine.
What parts I will need to complete the swap.
1. I guess some jumper harness is needed from my factory obd0 to obd1, right? What kind - some link or offer?
2. Gearbox mount, will this work?
https://www.innovativemounts.com/Pro...49123&CartID=1
3. Alreayd have Hasport hydro to cable bracket
https://www.jhpusa.com/store/pc/view...?idproduct=522
What am I missing?
Old Feb 15, 2016 | 01:40 PM
shopa's Avatar
Default Re: OBD0 to OBD1 jumper
someone....
Old Feb 16, 2016 | 01:20 AM
HondaPartsHero's Avatar
Technical Hero
OBD0-1 ECU adapter and distributor adapter. Search as many places sell combos. Reuse your current injectors or you'll have to remove the resistor box, cut and splice the Obd1 connectors onto your harness. You'll have to wire up a 4 wire oxygen sensor.
dc5itracer
10
Mar 26, 2011 10:29 AM
oldschoollove
14
Oct 1, 2009 03:01 AM
Dkahn18
Feb 18, 2009 04:41 PM
MugenMaster
Feb 25, 2008 09:33 PM
nitewolf
Sep 3, 2007 07:03 AM
