PA 2001 Acura ITR Drag Shell
Old Feb 10, 2016 | 10:05 PM
JroseEkb18c's Avatar
Default 2001 Acura ITR Drag Shell
2001 Inetgra USDM Type R Shell
$6500
37k Miles
R Title (Theft)
6pt Roll Cage
Vertex Steering Wheel
Jase Composites 3pc Front
Tucked Fuse Box, Brake Lines, Headlight Harness, and Battery box Under Driver Front Fender
Ground Control Coilovers with Koni Tophats
No Heat Or A/c
USDM ITR Seats
Sumped OEM Tank
-10an Fuel Feed, -6an Return
(2) Aeromotive Fuel Filters
Dual Bosch 044 Fuel Pumps with T1 Hanger
S2k Clutch Master Cylinder
Ktuned Traction Bar
Aluminum Catch Pan
Downstar Firewall Block Off Plates
Hawk Brake Pads
OEM Radio Block Off Plate
T1 Shift ****
BWR Short Shifter
Will Come on 1G DSM Wheels
I Also Have the Weld Wheels For Sale That Are Pictured
Fronts- 15x9 W/ 5" Backspace
Rears- 15x7 Street Setup
Both Have Upgrade ARP Hardware And Weld Lug Nuts
$1750
Located In Hughesville, PA 17737
Best Way to Contact Me Is Via Text @ 570-244-5638
You Can Also PM Me
I Can Provide As Many Pictures As You Want.
Old Feb 13, 2016 | 01:25 PM
Default Re: 2001 Acura ITR Drag Shell
Bump
Type R Albert
Dec 5, 2014 02:38 PM
Smokalicious
Sep 17, 2014 08:55 AM
gsrhb7
Northwest (Sales)
10
Jul 16, 2007 04:45 PM
iperez
Aug 21, 2002 09:37 AM
