Common issues with 1996 Civic
Old Feb 10, 2016 | 01:31 PM
Panici's Avatar
Default Common issues with 1996 Civic
Hey guys,
I'm considering picking up a '96 Civic.
Manual trans, 290k KM (180k mi).
Owner says he will get the car safetied prior to my looking at it.
Do these have any major issues? Things to look out for? etc
Thanks!
Old Feb 10, 2016 | 01:37 PM
jwest1150's Avatar
Default Re: Common issues with 1996 Civic
stock engine? what trim? also headgasket is common depending on the motor.
Old Feb 10, 2016 | 01:41 PM
Panici's Avatar
It's probably owned by a non-enthusiast, so I would assume stock engine.
I don't know any of the other details yet.
The ad is one of those single picture, 30 words types.
If he does indeed get it safetied I'll be heading to check it out and buying if it's in decent shape, so hoping to do some homework first.
Old Feb 10, 2016 | 02:18 PM
Deetz's Avatar
Crazy Honda Guy
Rust is the most common issue for that car. Hatches and sedans get the most, for some reason, the coupe is a better design and much more resistant.
Other common things are window regulator (easy fix) and the speed sensor
Old Feb 10, 2016 | 04:23 PM
Panici's Avatar
Yeah I figured with the rust. It looks clean in the pic, but if it's rusty that'll be a good point to get money off the price.
How's the D16Y7 ? I assume that's the motor in the car, as it doesn't appear to be an SI.
Old Feb 10, 2016 | 04:51 PM
jonsey1886's Avatar
10 Year Member
Other issues off the top of my head:
Oil leaks:
Valve Cover Gasket
Distributor O-ring and Gaskets
Cam and Crank Seals
Oil Pan Gasket
Rear Main Seal
Do a tune up-a lack of one anytime recently can be a common issue depending on how you look at it: DIY 96-00 Honda Civic Tune up and fuel filter - Honda-Tech
Vacuum leaks
Old Feb 10, 2016 | 06:27 PM
Panici's Avatar
Alright, thanks guys.
I'm hearing normal type issues, nothing special that stands out.
Old Feb 11, 2016 | 01:41 AM
eghatch9295's Avatar
Stancetard Hate Monger
no one has mentioned rotten subframes.
Old Feb 11, 2016 | 02:46 AM
Jimi Hondrix's Avatar
As many head gasket and overheating replacement post each week..you'd think they are a common issue. OP do yourself a favor and replace any suspect or visibly worn coolant/heater hoses...especially the heater hose under the distributor. The distributor's O-ring is a common place for oil leaks and if there is an oil leak there now or one prior then that oil leak will damage that heater hose.
Check and change (if needed) the PCV valve as soon as possible. Best to do it when changing oil and filter is off. To check it .. shake the PCV and if the ball inside rattles it's still good. Replace those every third oil change. Neglecting the PCV can lead to oil leaks and could cause a rear main seal leak.
NJC1684
Honda Civic (2006 - 2015)
Nov 15, 2018 02:56 PM
Gerlach0130
Jul 13, 2014 09:03 PM
SamFromRiverside951
21
May 30, 2009 07:27 AM
imzjustplayin
26
Apr 20, 2008 03:48 PM
