Ys1 crx.
Old Feb 9, 2016 | 05:16 PM
EdwardPhipps's Avatar
Default Ys1 crx.
Ys1 front gearbox mount. While I was doing up bottom bolt of Mount it has cracked the bellhousing from the bolt end to bolt end . What's a good way of fixing this issue .. apart from from getting new mounts etc .
Old Feb 10, 2016 | 12:40 PM
v4lu3s's Avatar
RTFM
Default Re: Ys1 crx.
you replace it or weld it. nothing else will work.
Old Feb 10, 2016 | 01:41 PM
Deetz's Avatar
Crazy Honda Guy
The ys1 cable gearbox was found on all manual versions of integra 1992-93. Though they looked the same, the ls version had taller gears than the 4.4 FD and gears found in GSR models.
The casings were the same, you could source one out, if it's worth it, depending on what version you have
Old Feb 10, 2016 | 01:59 PM
Yeah took me a while to find that gearbox its the 4.4 final drive with an aftermarket lsd. Cost me 800 so I guess i'm welding it up then. Can you tig it ?
Old Feb 10, 2016 | 02:01 PM
yeah that's what i thought ! You have to use TIG huh ?
Old Feb 11, 2016 | 05:16 AM
kp's Avatar
kp
Basically, yeah. TIG gives the best end result on aluminum. Cast aluminum is a little tricky to weld effectively, so choose your welder wisely if you want the repair to last.
GroundZer0 336
Jun 29, 2008 10:38 AM
gnar kill
Feb 25, 2005 09:54 AM
Mr.Saturn
Feb 13, 2004 02:50 PM
whitemike1644
Jun 10, 2003 03:31 PM
cvcc
Jan 5, 2003 09:35 PM
