Suspension & Brakes Theory, alignment, spring rates....
spring and shock or coilover suspension?
Old Feb 9, 2016 | 07:55 AM
cupofjoe619's Avatar
Default spring and shock or coilover suspension?
I have a 94 VTEC Del Sol I want to drop. It's also an everyday driver. I just want to get an idea of what anyone's thoughts were between the 2. Im leaning towards Tein springs and a quality shock OR Tein coilovers but I also want to do it right the first time. I'm not a huge fan of coilovers as Iv'e seen them on my friends vehicle and haven't been impressed. It's possibly due to the adjustment setting they have it set on, idk? thanks
Old Feb 9, 2016 | 04:06 PM
KoRn_vIRuZ's Avatar
Default Re: spring and shock or coilover suspension?
The Del Sol comes with coilover suspension from the factory. So the difference between going with a shock/spring combination and what is usually called a coilover, assuming equal quality for both setups, will be the ability to infinitely adjust height to your liking and also corner weight the car. Is that something that appeals to you? Then buy coilovers. If not, a shock/spring combination is good too.
Old Feb 10, 2016 | 04:28 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
What did you not like about height adjustable coilovers? Apples to apples, they are almost always quite a bit better than springs/shocks in terms of ride quality and handling.
Old Feb 10, 2016 | 09:33 AM
OxDseries's Avatar
Hi Guys... Well I have Del Sol S 95 and I have Coilovers setup on the front and lowers springs on the rear.... Coilovers is a setting that is rigid will have an effect on the roof, it is heavy, and will start sounds lose and that's annoying.... Lower Springs its better for a DD...
RedlineMotive
Jun 18, 2012 09:23 AM
YipMan_Style
Suspension & Brakes
Jun 29, 2007 05:45 PM
Aphrodavid
Nov 27, 2002 12:42 PM
anjapower
Oct 17, 2002 11:46 PM
