del sol wheel offset?
Old Feb 8, 2016 | 05:31 PM
cupofjoe619's Avatar
Default del sol wheel offset?
Hey everyone. First post. New to the forum.
Trying to get some new wheels for my 94 VTEC Del Sol. I have a question in regards to the size/offset. The wheels I'm looking to get are 15x6.5 with a +42mm offset. I obviously know that 15x6.5's will fit but what I was wondering is if that would work or are the offset specs incorrect for the Del Sol? any info would be great. thanks!
Old Feb 8, 2016 | 06:12 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: del sol wheel offset?
Yes, that's within the proper range for your car.
Old Feb 8, 2016 | 07:18 PM
thanks I appreciate it!
what is the tolerance/range for the offset if you don't mind me asking? or does it change with rim size/width?
Old Feb 8, 2016 | 07:27 PM
NotARaCist's Avatar
It varies depending on the wheel size.
Old Feb 8, 2016 | 08:59 PM
Thanks again!
Old Feb 8, 2016 | 09:22 PM
93egSLEEPER's Avatar
That is basically a stock size wheel which will fit no problem at all. What size tire did you plan on running?
Old Feb 8, 2016 | 09:57 PM
Idk. I was looking at a 50 size but I want something meaty for it width wise. I realize that's relative to the size of the rim however. Open to suggestions...
Old Feb 9, 2016 | 06:16 AM
205/50-15 (meatier) or 195/50-15 would be my choices. If you click the link in my sig to my build thread I have a pic of my car on 195/50-15 w/ GSR blades which are almost the exact same spec as the wheels you are buying.
Sylendrian
Jan 6, 2019 05:05 PM
SlowIntegraLS
Mar 7, 2007 02:33 PM
Elwuudz
May 2, 2006 11:32 PM
Elwuudz
Mar 28, 2006 06:23 AM
phantom_sol
Jul 26, 2003 12:12 PM
