ZC pistons in a DX motor?
anyone know for a fact if you can use ZC pistons in a DX motor?
will ZC pistons connect to the stock d15b2 rods?
will there be any clearance problems in the head?
can you use new stock d15b2 rings on ZC pistons?
any other useful info i should know?
Yes ZC pistons will fit in your motor, both DX and ZC and lots others share the 75mm bore. Yes they will connect to your rods, DX rings should fit fine as well, if not, 89 integra P29 rings will fit too. Clearence problems will not most likely be a problem, your compression wil boost up a little.
apekd
Mar 26, 2009 11:20 AM
