H22 swap help
Old Feb 6, 2016 | 07:31 AM
Chubby17's Avatar
Default H22 swap help
I have a 94 civic ex and swapping in a 94 prelude h22a was wondering the difference do I need to use a 92-96 shifter box and cables or am I able to use the 97-01 box and cables
Old Feb 6, 2016 | 09:24 AM
dfanatic86's Avatar
Default Re: H22 swap help
92-96 Shifter metal
97-01 Shifter plastic
Both do the same job as long as you mount them correctly. Mounting holes appear to be different, but that doesn't matter as you will tailor your own. Also it's note worthy to make the final adjustments after the engine is mounted and 100% bolted down. You can also use the Accord shifter as well. Hope this helps you out.
Old Feb 6, 2016 | 09:39 AM
Chubby17's Avatar
So the cables are the same the only difference is the mounting holes and the one is plastic correct I will be making my own mounting holes that's a given pretty much seen as how the civic isn't a cable shift
Old Feb 6, 2016 | 09:59 AM
dfanatic86's Avatar
I'm going to lean on that they are slightly different lengths. I will say this though, get the cables for the shifter you are using. If you need the cables and the shifter, why not get them together?
Old Feb 6, 2016 | 10:11 AM
Chubby17's Avatar
I will be buying them together but was trying to figure out the difference besides plastic and metal and the price that is
Old Feb 6, 2016 | 11:35 AM
dfanatic86's Avatar
I've dealt with both before and I didn't notice any differences. If your patient I've seen them online for under $100.
DeeJHonda95
Transmission & Drivetrain
Feb 13, 2014 04:50 AM
deuces
Feb 24, 2007 03:48 PM
Maddox
Apr 17, 2005 08:32 AM
h22-cx-guy
Jun 30, 2004 11:40 PM
sol-racer
Mar 6, 2002 01:07 PM
