Honda CR-V & Element 2WD & 4WD Element & CR-V
99 Manual Trans Swap. Electrical issues,
Old Feb 3, 2016 | 05:40 PM
Brodzko's Avatar
Default 99 Manual Trans Swap. Electrical issues,
Well I have a 99 Crv that had factory auto everything and now has the 5 speed in it. But after messing with it , I can't get it to turn over using key switch. This has become a bit of a nightmare.
There was another thread on here that mentioned using and auto harness and need to bypass the NSS and trick the clutch safety switch. The original author has not been on since 2013 and will not be able to contact obviously.
Any more info would help. Or a push in the right direction.
Also the key will not come out of ignition while under power.
Thanks in advanced for your help
Old Feb 3, 2016 | 07:16 PM
EJ8_Man's Avatar
Default Re: 99 Manual Trans Swap. Electrical issues,
Did you follow a guide? See if this guy did something you didn't. https://honda-tech.com/honda-element...rsion-3068556/
pvang027
Jan 31, 2013 04:24 PM
dragged
Apr 26, 2012 11:59 PM
streetelementcc
Oct 8, 2011 09:19 PM
datnigabluberry
Mar 13, 2006 10:00 AM
bouttobeout
Mar 12, 2004 02:36 PM
