Are Cutting Stock Springs Safe??
Old Nov 6, 2002 | 03:20 PM
LS AnGeL's Avatar
Default Are Cutting Stock Springs Safe??
I just wanted to know because we cut my freinds today, I also wanted to know how long will they last. Thanks!
Old Nov 6, 2002 | 03:21 PM
vtec69's Avatar
Default Re: Are Cutting Stock Springs Safe?? (LS AnGeL)
NOOOOO
DOnt do it your shocks will blow out in like a week
Old Nov 6, 2002 | 03:24 PM
isotopesope's Avatar
it's safe as long as you have altezza taillights too.
Old Nov 6, 2002 | 03:25 PM
2.0L EK's Avatar
Default Re: Are Cutting Stock Springs Safe?? (vtec69)
I dont think safty is really the right question.
cut springs =
Reliability
comfort
handling
looks
Your car will become extremly bouncy and the shocks will blow out really fast!
So for cutting your springs i give it
Old Nov 6, 2002 | 03:26 PM
YodaIsGod
Guest
Posts: n/a
NO!!
your friend is a dumbshit for doing it.
I guess you want "more bounce to the once than a jerri-curl" ride then.
Old Nov 6, 2002 | 03:34 PM
mantic6t9's Avatar
Default Re: Are Cutting Stock Springs Safe?? (YodaIsGod)
Not a good idea
Old Nov 6, 2002 | 03:37 PM
Bricklayer's Avatar
If you cut your stock springs your tires will rub in the fender a little too much, and you will probably bottom out more than you would like. when you get lowering springs they are usually much stiffer than the stock to compensate for the ride height being lower, tell your friend to suck it up and get some real springs and don't ever cut your springs.
Trac226's Avatar
Default Re: Are Cutting Stock Springs Safe?? (mantic6t9)
"Cutting" and "springs" shouldn't be used in the same sentence here.
Old Nov 6, 2002 | 03:38 PM
Dr. EKology's Avatar
Best thread ever!!
Don't cut them you cheapo! Get a nice set of springs like Neuspeed race springs or something.
Old Nov 6, 2002 | 03:42 PM
CiViC SiR's Avatar
Default Re: Are Cutting Stock Springs Safe?? (EKology)
i have cut my springs on my civic si 99 and no problems until now its almost 1 year
[Modified by CiViC SiR, 3:49 AM 11/7/2002]
Old Nov 6, 2002 | 03:44 PM
Hyjnx's Avatar
Default Re: Are Cutting Stock Springs Safe?? (CiViC SiR)
OMG....Cutting ? might as well get a blow torch, and then put some weight on the car so it sinks!!
-Whitey-'s Avatar
we just heated the springs on my buddies winter beater its an old *** vw jetta i think its a 1984?
we also made a cai for it with two filters and we blacked it all out with flat black and next this coming weekend were gonna put 2 12's in it...its gonna be ghetto fabulouse(sp)
Old Nov 6, 2002 | 04:05 PM
Dark Halo's Avatar
What the hell are you thinking!? That just doesn't sound logical any way i try to look at it. "I'm going to CUT my springs"....hmmm...does that sound safe in any way, shape, or form? Just say it outloud and think about what your saying. While your at it, just cut your brake lines, and maybe some of the hoses under the hood too. I promise, it's safe.
Old Nov 6, 2002 | 04:18 PM
desync's Avatar
Cutting springs is bad mmmkay?
Expect the car to drop another 2 inches over the next few months.....
It's "better" (though not bye much) to heat them because the same about of spring is there......
Now there's the same amount of weight on less spring, give it sometime and the spring will loose it's strength and start to lower even more. Not to mention blow struts in the next few months too.
Old Nov 6, 2002 | 04:20 PM
2FASTDC2's Avatar
Default Re: Are Cutting Stock Springs Safe?? (desync)
not a good idea, just spend the $ more some decent springs.
Old Nov 6, 2002 | 09:28 PM
DaddyFatSacks's Avatar
Default Re: Are Cutting Stock Springs Safe?? (YTRY)
good thinking...
Old Nov 6, 2002 | 09:34 PM
2camsaam's Avatar
Default Re: Are Cutting Stock Springs Safe?? (DaddyFatSacks)
they're good if you are trying to learn the Bankhead bounce while driving.
Old Nov 6, 2002 | 10:07 PM
TheIntegraGuy's Avatar
Default Re: Are Cutting Stock Springs Safe?? (2camsaam)
Go ahead..Cut them..They'll be fine...Don't listen to anyone else. Ride will be smooth as ****. Especially with stock springs..hell yeah...springs coming out of the sockets and ****, I give it a 2 thumbs up.
NO...Don't cut them. You'll die.
Old Nov 6, 2002 | 10:15 PM
94hondaLS's Avatar
Default Re: Are Cutting Stock Springs Safe?? (Esone3)
depends how much you cut them.
Old Nov 6, 2002 | 10:18 PM
Danbu$'s Avatar
Why cut them ?
just take the springs out, it will make any car handle like a race car !
well that and a vtec sticker !
but if you wanna go all out, why dont you get some altezzas and make your car into a full race car.
Old Nov 7, 2002 | 12:17 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Are Cutting Stock Springs Safe?? (Danbu$)
Stock springs is a big no no. If you cut no more than a coil for lowering springs, it should be fine.
Old Nov 7, 2002 | 01:10 AM
EddieHatchBlack's Avatar
dont cut!!
Old Nov 7, 2002 | 01:14 AM
chillly's Avatar
Default Re: Are Cutting Stock Springs Safe?? (94hondaLS)
Uh, no. Cutting springs is not a good idea under any circumstances, period.
Old Nov 7, 2002 | 01:19 AM
D16Z6racing's Avatar
Default Re: Are Cutting Stock Springs Safe?? (uncivilCivicinprogress)
I feel sorry for the guy driving the car, even though this is part of his stupidity.
I just drove a 88 Prelude S w/ cut springs. My head started to hurt within 1 minute. I'm a tall peson and all that boucning around did was hit my head into the ceiling.....constantly. I had a hat on too, and I hate that hard thing on the top of hats. It hurts like hell when it gets jammed into your head.
Old Nov 7, 2002 | 02:22 AM
B2FiNiTY's Avatar
Default Re: Are Cutting Stock Springs Safe?? (buster13)
oh please....
