no start 92 accord
I went out the other day and the car cut off and would not start. Got it towed and it would crank but not start. I replaced the plugs,dist cap and rotor and charged the battery. When i went to get the battery tested talked to the guy there for a $ on the coil(never did get one). He said hondas are bad for the key switch$($50.00 wires to or could be the distributor(150.00). Car is a 92 accord 4 cylinder. Could it be anything else? Are those 2 items or 1 bad to go out? Any other info help full and thanks
Need to narrow it down between spark or fuel. Hook up a timing light and see if you are getting spark on cranking.
Then open the fuel rail bleeder and see if you have any fuel pressure, if you do, put in a fuel pressure gage and see how much you have.
mikes78
Aug 23, 2005 06:11 AM
