F20b swap to 99 Lx
Old Jan 26, 2016 | 03:24 AM
prwil3030's Avatar
Default F20b swap to 99 Lx
So, I'm getting ready to do the F20b swap to a 99 Lx and I had already read in the forum that the swap should be a direct fit but also read about some issues like fuel pump and temp gauges not working, no my questions are the following. I'm planning on using a P28 chipped ecu with F20b base map, do I need the OBD2a or OBD2b jump harness? Also, if I use this setup Will I run into the same issues with the fuel pump not working?
Any help will be greatly appreciated
Old Mar 2, 2016 | 06:51 PM
fredd3030's Avatar
Default Re: F20b swap to 99 Lx
i guess no body knows!!
Old Mar 4, 2016 | 08:15 AM
Aradin's Avatar
Premium Member
You will need the OBD2B harness. As far as the fuel pump, not sure - never heard of that issue. For the temp gauge, I believe that's correct when you use a different ECU than stock on those models. I know it's true for Hondata anyway.
You're gonna need to do better than a basemap to get any benefits from your swap.
Honda-Chris
Apr 2, 2019 04:17 PM
eghatch9295
11
Feb 8, 2019 04:21 PM
p.bass
Nov 7, 2014 06:32 PM
boostin99em1
Jan 18, 2011 09:28 PM
918-Hatch
May 24, 2005 05:39 PM
