UNEVEN RIDE HEIGHT
Hey everyone , so my integra (94 gsr if that helps in anyway) is lowered on some d2 racing springs with tokino shocks , well when i first installed this set up everything was fine , ride height was all even on both sides , was very stiff ( how i like my ride quality ) , and everything was fine , then my rear passenger popped out due to a bad washer ( don't ask me i am still puzzled till this day ) so i took it out and fixed the problem , then i noticed that my car was sitting funny and my ride height was about half my hand , and on the other side was not even past my fingers , so i was like dang , my ride heights are completely different , i gave it 2 weeks just in case they needed to set again , and still no difference , ANY HELP i need to figure this out it looks dumb and i would love a cure guys , anything helps THANKS in advance
I believe you mean BEFORE the tophat. That shouldn't affect ride height. Its something else that will require you to investigate all 4. YES ALL 4. What you can do is start with the corner that doesn't belong.
oh man, is it really just a washer? It's supposed to be a TAPERED piece of (roughly) 1/4 inch steel. Looks like a washer, but its not. Usually part of the strut cover. Other wise mounted under that. I have the pillowball mounts on mine, but you can see the "washer" type object on the bottom, its tapered so it doesn't slip out of the hole. You actually cant see the rest of this, but it goes down INTO the mount.
