Turn Signal Turns On Hazard Lights (civic eg)
Old Jan 20, 2016 | 09:54 PM
andoshan's Avatar
Default Turn Signal Turns On Hazard Lights (civic eg)
Hello all,
Hazard switch works normally. Left turn signal works normally. Right turn signal turns on Hazard lights. All lights function normally except the right turn signal. arrrgh
A bit of history; It's been sitting in garage for a while. After I did the motor swap the right turn signal was still functioning normally.
I think the only thing I've done since is removed the Password JDM fog light harness which I doubt is the cause as the harness was not functioning anyway.
One day took it for a drive and it just started happening.
What I've tried doing:
-Replaced the hazard switch(didn't work)
-Check fuses(will double check again tomorrow)
-Changed the "To Turn Signal/Hazard Relay" in under dash fuse box
-Taken out the cluster and used the Right turn signal indicator(didn't work)
-Try to find other forum threads with similar case(only 1 guy had similar issue and recommended to change hazard switch...didn't work)
Any idea's would be appreciated
Old Jan 20, 2016 | 10:25 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Turn Signal Turns On Hazard Lights (civic eg)
Remove the front bulb. Does it still do it? Reinstall the front, remove the back bulb. Does it still do it?
Old Jan 21, 2016 | 12:27 AM
andoshan's Avatar
Gave that a try just now. No luck. Even switched the left and right bulbs around, still same thing. Even if unplugged it still does the hazard lights(right side signal) zzz.
fourblades
May 7, 2015 09:18 PM
Pabs626
Jul 17, 2007 10:25 AM
BrownGSR
Mar 16, 2004 09:19 AM
