ID1000 O ring for AEM rail
Tried fitting my Id1000's on my aem fuel rail last night, The top O-rings are just barely to large to fit properly. Already ripped one o-ring last night and that was with using oil as a lubricant. (they fit fine in the OEM rail). I believe its a combination of both AEM and ID attempting a snugger fit then OEM, which when combined its just too tight
I have already contacted both Injector Dynamics as well as AEM, with little to no help.
My next step is to try OEM O-rings
just curious if anyone else has ran into this
But I know what you mean I had that issue with my FIC injectors since they are so short
Yeah. Oil, and slowly turn injector back and forth to kind of roll the o ring into place. You could try a hair dryer to warm up the aluminum rail and gain some clearance.
Thanks guys, this is pretty much what I was doing. Ill try again once I get my honda OEM o-rings since I have already Ripped one of the original O-rings.
had to add them to my majestic honda order. Local dealership wanted 3.74 Each o-ring LOL
EFb18b
Apr 9, 2004 01:04 PM
1badda
Feb 12, 2004 10:00 PM
