Honda CR-V & Element 2WD & 4WD Element & CR-V
In the market for crv - what to look for?
Old Jan 17, 2016 | 09:33 AM
seearevee's Avatar
Default In the market for crv - what to look for?
Not completely sure if this is a previous thread, if so, someone link it please cause I couldn't find it. anyways, im in the market for a 1st gen crv, and I think ive found a good one. can anyone recommend anything to look for that could be a problem. im familiar with Hondas, and the b-series motor. but not with crv's. any tips are much appreciated. one thing I noticed when I went to look at the car the first time was that when I turned the radio on it just read " code ". what could that be? thanks!
Old Jan 17, 2016 | 11:26 AM
Johnnyrox's Avatar
Default Re: In the market for crv - what to look for?
The code is for the radio/stereo, it means that the battery died or was disconnected. The code might be written down some where in the owners manual or you might have to get the serial number on the stereo it self, and then honda or someone in here might be able to find the code for you. One main thing to look for is the timing belt and valve adjustments were done.
Most first gens nowadays will probably have a rough, squeaky or clunky ride due to worn dry out bushings, nothing to worry about though unless its a balljoint then it might snap ( not a fun experience).
Other than that if you are familiar with Hondas then just look for the things you would usually look for.
They are pretty cool little rigs. My brother in law gave my wife his 99 and I liked it so much I bought one for myself.
Old Jan 17, 2016 | 12:00 PM
seearevee's Avatar
okay sounds good, thanks a lot! hopefully sealing the deal on Tuesday. will post pictures if everything works out.
Old Jan 18, 2016 | 06:18 AM
EJ8_Man's Avatar
Sometimes crooked sellers disconnect the battery (and lock out thd radio) to clear check engine lights. This CRV may be throwing a code. Give this CRV a good test drive and bring a scanner with you
Civic Racer X 7
May 11, 2016 07:14 AM
alex_belarus
Nov 21, 2007 02:37 AM
Sick'Lude
Nov 10, 2005 02:15 PM
BGreenlee
Jul 23, 2005 08:05 PM
pink hatchy
12
Feb 21, 2005 03:37 AM
