Car won't start
Old Jan 17, 2016 | 01:23 AM
ldelgadol's Avatar
Default Car won't start
I have a 1989 honda crx si and I recently switched out the wireharness and during the removal of the old harness the owners before connected the starter cable that receives the 12 volts directly to one of my ignition switch plug wires that's black with a white stripe. Now that I replaced both ignition switch plug and harness my car won't start. My lights from my dashboard light up but when I tried to start it now power. Where is the starter connected to where it receives power when the key is turned to start the engine and what can be a problem it won't send the power?
Old Jan 17, 2016 | 04:33 AM
Sikocivic's Avatar
Default Re: Car won't start
What harness did you replace and why?
Old Jan 17, 2016 | 10:41 AM
ldelgadol's Avatar
Replaced the main engine harness because the old one was modified which was causing a short and my car to shake and turn off.
Old Jan 18, 2016 | 02:33 PM
whited's Avatar
CRX God
check your fuses. Are any blown?
Old Jan 18, 2016 | 02:51 PM
eh2_Trav's Avatar
I know im saying what youve probably read already but there is a ground on thermostat that runs off the harness, since you changed out your harness make sure you hooked up you ground wire and check all other ones.
Old Jan 20, 2016 | 11:11 PM
Ameedoe's Avatar
check the ground wire that goes on the thermostat housing.
Very important. Grounds the ecu
LOL, ^didn't read the post above me.
Old Jan 21, 2016 | 09:19 AM
eh2_Trav's Avatar
Smart thinking lol
hellalaaag
May 5, 2014 12:38 AM
F22B Accord
Apr 21, 2014 03:00 AM
GSRinmyCRX
May 20, 2012 05:44 PM
MassScene
Jan 25, 2007 04:04 PM
