cam gear setting with ITR b18c5/6 cams in B16a
Old Jan 16, 2016 | 08:08 AM
gabrielsousa's Avatar
Default cam gear setting with ITR b18c5/6 cams in B16a
what are the best degrees in intake and exhaust ?
i will install ITR b18c5/6 cams and BWR cam gear
my engine is a b16a1 stock, with ITR intake and exhaust manifold
Old Jan 16, 2016 | 10:55 AM
v4lu3s's Avatar
RTFM
Default Re: cam gear setting with ITR b18c5/6 cams in B16a
I would run 0/0 until tuned on a dyno.
Old Jan 19, 2016 | 10:32 PM
thanks
i can have more power with other settings ?
Old Jan 19, 2016 | 11:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Maybe... maybe not. If the head hasn't ever been milled, and the block is virgin as well, it will likely make maximum power with the stock cam gears. Adjustable ones look pretty... make sure you get a quality brand set (NOT from Ebay) and you might just pick up a few (yes, like 2-4 wheel HP) if you try different settings on the dyno. This type of testing is time consuming and costly for the potential HP increase, unless you have a really generous tuner... or cam tuning is included in the tune price.
Old Jan 20, 2016 | 03:07 AM
v4lu3s's Avatar
RTFM
Originally Posted by gabrielsousa
thanks
Probably not on stock cams. with dyno time you might get a little as the other guy suggested though usually it's at the expense of power in other areas. Like gain 4 peak hp and lose bottom end power
Old Jan 27, 2016 | 07:10 AM
are this the specs of itr cams ?
INTAKE
Max valve lift - 11.5 mm
Intake opening 15 deg (BTDC)
Intake closing 45 deg (ABDC)
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST
Max valve lift - 10.5 mm
Exhaust opening 45 deg (BBDC)
Exhaust closing 10 deg (ATDC)
EXHAUST lift - 10.5mm, duration 235 @1mm
Quickridez_3
Nov 10, 2006 01:22 PM
CANTFAZZDISCHIT
Jan 11, 2004 01:25 PM
Black B16A
Aug 8, 2002 12:20 PM
Maximo
Jun 5, 2002 07:58 AM
bananacruzier
Feb 4, 2002 05:52 AM
