Suspension & Brakes Theory, alignment, spring rates....
Coilover Help
Old Jan 15, 2016 | 12:28 PM
Chris Auney's Avatar
Icon4 Coilover Help
Hello, I have a 95 honda ex that's lowered on coilovers (not sure what kind) but they only have 2 adjusting rings and I'm not sure how to adjust them. If anybody knows or has seen a video online I would really appreciate the help.
Old Jan 15, 2016 | 01:22 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Coilover Help
You need 'coilover wrenches' or perhaps an allen key to loosen the rings. They 'lock' together against each other.
Now, nobody can help you unless you take a picture of your coilovers to show us what exactly you have. If they are dirty, clean them first, as markings/coloring can help determine what you have.
Old Jan 15, 2016 | 01:42 PM
Andy@AMR's Avatar
You most likely have traditional locking collars which are a butt fit. As stated above they lock against each other. Picture a bolt and taking 2 nuts and turning one counterclockwise and the other clockwise locking them in place against each other. Those can be a pain to break loose. If you don't have the wrenches, we've got some universal ones on our site. Good luck. I'd make sure to have a good sledge hammer handy to help break them loose if they haven't been adjusted in awhile.
You could also use a LARGE flat head screw driver to break the bottom collar loose, it's not ideal, but will work.
Da_1991
Jan 29, 2012 08:06 PM
leath213
Jun 26, 2002 04:11 PM
