97 VTEC Solenoid Oil Leak, Upper gasket ?
Old Jan 14, 2016 | 04:02 PM
homebrew01's Avatar
Default 97 VTEC Solenoid Oil Leak, Upper gasket ?
1997 Accord SE 4 cyl. 242k miles
I see oil dripping from the solenoid. It looks like it coming from one of the 3 mount screws on the top. Looks like I can just remove the top portion, and replace a gasket, without having to remove the whole unit from the engine ?? Should be simple, if that's where it's leaking, right ??
I'm not sure what part I need for replacement though, such as correct name and part # and if a parts store is likely to have it, or dealer only ?
Are little parts going to go flying when I open it, or any "gotchas" I need to watch for ?
Thanks for any help.
Oil leaking from below this bolt
Old Jan 14, 2016 | 05:22 PM
HonBeer's Avatar
Default Re: 97 VTEC Solenoid Oil Leak, Upper gasket ?
First off. Clean that so you can see exactly where the leak(s) are.
Old Jan 14, 2016 | 06:16 PM
homebrew01's Avatar
What's the best way to clean ?
I looked at it pretty closely while running, and with a mirror on the backside, and 99 % sure it's leaking around that bolt. I could see oil oozing out both sides of the flange.
Old Jan 15, 2016 | 02:10 PM
HonBeer's Avatar
Parts washer brush with simple green.
Old Jan 22, 2016 | 11:56 AM
homebrew01's Avatar
I bought the solenoid gasket online for $4, installed in about 15 minutes, and no leak for 3 days !!
BamaSkater09
Dec 8, 2013 04:24 PM
sma_V6
Jan 17, 2011 01:22 PM
3k9civic
Apr 24, 2005 04:39 PM
srburk
Feb 6, 2005 04:35 AM
trooper0641
Sep 9, 2004 04:57 PM
