Mugen Showa suspension riding poorly
Cool Cool Island Breezes. BOY-EE
How low are you riding? Did you buy them used? Original spring rates? Same model as your last mugen suspension?
They aren't height adjustable, its fixed. Only 3/4" lower than stock?
Bought them used, yes.
Springs look like they're original to the shocks. I believe there was only 1 model and set of specs for the lowdowns.
How many miles total on them? Any sign of them leaking?
You may need to take them off and physically check them and see if adjusting the dial does anything to either compression or rebound.
Unfortunately, I don't think the Lowdowns are rebuildable, but you may want to call King and confirm.
As a side note, I wish they were still available new. I love the slight upgrade from stock they give you.
Just doesn't seem like they are responding to me turning the screw to a lesser rebound if that makes sense.
How could I check to see if the screw is doing anything by removing them?
Overall they ride well, just when I go over bridges, hit potholes or hit something aggressive its quite noticeable that its super stiff and doesn't give much. Crashes over hard conditions.
They are technically "high performance" shocks. They won't have the lifespan than your OE units will. If I had to guess, I'd expect signs of that shock beginning to wear out at about 40-50K miles or so. All shocks die over time.
A simple "push" test on the shock shaft should show differences between setting 1 and setting 5. That won't tell you the shocks health, but it should result in one setting being "different" than the other either via rebound or compression.
Bad shocks ride well on smooth surfaces, then you hit a pothole or bump...
Incorrect. The lowdowns were an entire assembly: shock, spring and tophat. You're thinking of the N-Zero and N1 kits which were only sold as dampers and perches. You had to buy the spring for those and reuse your OE tophats.
Called kingmotorsports and mugen 5-way suspension are not rebuildable. Seems like my shocks may be blown from the symptoms I described. They could be upwards of 10 years old.
Going to keep my eye out for a good deal on kw variant 2.
V2's are a nice setup though. I have V3's on my MX5 and I couldn't be happier with them. Too bad Mugen stops making parts for cars once a newer model of said car is released.
The only thing I don't like about KW V2's is that they only adjust rebound damping. Unless I'm mistaken and there is some bump adjustment per click?
I know that rebound makes the biggest difference. But for a set spring rate, I think a logical curve to adjust bump and rebound together is advantageous.
Try turning the adjustment **** past the 5th click in either direction and then adjust the dampening like if you started over again. Had the same problem when I had my low downs.
If you decide to get something else, PM me if you want to sell the lowdowns. I've been wanting to find a set that's beyond their service life but not rusty. I have some new H&R standard rate springs I'd also trade you that would fit on a set of coilovers should you decide to go that route.
Have tried this. I've turned them well past the 5th click to "re set" them and tried over with no change. Going to try it again.
Same here, got mine used from a reputable source ... then gave them away.
Felt somewhat similarly about a set of PIC that I'd had (also given away, though I have another set for backup if Motons need service), though I must be spoiled in that my Moton 3-ways are just fine.
Too bad I can't ride in someone else's car that has them to compare to truly see if mine are messed up.
Seems to have helped. Super hard to tell from minor changes.
If you look around, you can get a Koni yellow/GC setup (with rates of your choice) for around $1000. Best setup for the money IMO.
