Heater wont work
Old Jan 9, 2016 | 08:40 AM
Teggy_DC2's Avatar
Default Heater wont work
96 teg
New thermostat, all hoses are hot, flushed heater core. No air bubbles, left the car on with no radiator cap for almost an hour. Door blend works, valves operates fine to but still no heat! Help!!!
Old Jan 21, 2016 | 06:03 PM
Drzhope89's Avatar
Default Re: Heater wont work
could be a bad radiator clogg not enough flow
Old Feb 4, 2016 | 08:43 AM
trm4life's Avatar
Wow...I'm a little stumped, personal opinion. T-stat installed incorrectly or heater core just bad...but don't they leak when they are bad?? Or heater hose leaking?
Old Feb 4, 2016 | 11:55 PM
Natsu09's Avatar
Does the blower motor come on at all?
Old Feb 7, 2016 | 01:29 PM
Beto_619's Avatar
could be blower motor not working.
Old Feb 11, 2016 | 12:29 AM
wunfstgsr's Avatar
Loved
Community Favorite
check the cable latch on the valve on the hose by the fire wall inside the engine, sometimes the vent on the climat control seems to move fine from cold to hot but the cable can get stuck leaving the valve closed, manually opent the valve if thats the case.
or your blower is not working but if its blowing cold air its working.
integradc4_rg87
Oct 29, 2010 11:51 PM
nitewolf
15
Oct 28, 2010 05:15 PM
Shaw14
Dec 21, 2009 12:30 PM
honda4674
Jan 20, 2006 06:53 AM
scdarksol
Jan 25, 2004 08:24 PM
