Power Steering Pump Part #
This part number PT0 164242N is on a sticker on top of my power steering pump but I can't find the part # anywhere online. Is it a Honda part? I'm thinking of putting regular Prestone p.s. fluid with stop-leak in it. I own a '90 Accord. It's a mess. Power steering foams up. It leaks I believe from the p.s. gearbox when it's cold. Rack & pinion boots are tore off. Needs a complete front end overhaul. If it's not a Honda p.s. pump then I'm gonna get the regular Prestone fluid. I'm not gonna fix this thing. If I were better off financially I would. I'm in Texas so this cold aint gonna last long. When it's not cold the p.s. fluid loss slows way down. Thanks
That part number is probably a reman.
If that part number is a remanufactured p.s. pump you think it'd be ok to put regular prestone fluid w/stop leak in it? I think I'm gonna. This 90 Honda is on it's last leg anyways.
FMohlmann
Nov 18, 2016 12:28 PM
murrellington
May 8, 2014 03:30 PM
