96 accord h22swap
Old Jan 7, 2016 | 05:49 PM
Michael Watson's Avatar
Default 96 accord h22swap
I have a 96 accord lx 2.2 vtec and I want to a h22a swap what I can't get is a straight answer can I use a 97-99h22a or do I need to use the same year h22 can I use the old tranny or do I need to change that. Any help would be great I don't what smart *** reply I need truths and help
Old Jan 8, 2016 | 11:53 AM
Mike1015's Avatar
Default Re: 96 accord h22swap
Yup the h22 mounts directly on to the f22 tranny. Not sure If the harness is identical to the 96 accord since its obd2 it is on the h22a4... obd1 is h22a1. For the h22a1 to fit into a obd1 accord all it needs would be the h22a1 ecu and the wire harness would be a direct fit except for the IACV just need to extend the wire...
Old Jan 8, 2016 | 12:15 PM
v4lu3s's Avatar
RTFM
if you need to pass emissions it gets weirder.
specially if you are in cali...
Old Jan 9, 2016 | 12:25 PM
hybridmiklo's Avatar
the mounts are not the same. I did the swap a year ago. you need a 92-96 prelude driverside mount and shave it a few. You can use a h22a prelude ecu but its difficult to find the one without an immobilizer. On the swap I did i converted it to obd1 to avoid the hassle of trying to find the specific ecu. You are going to have to extend certain parts of the harness but thats easy.
Old Jan 9, 2016 | 01:55 PM
Aradin's Avatar
Premium Member
This has been very well documented a million times over. Don't spoon feed people. Make them do their own research like the rest of us. OP, google is your friend.
01sdime
Feb 2, 2012 11:04 AM
drummer0488
Jan 26, 2009 05:14 AM
Redek4
Dec 21, 2003 11:59 AM
B18PoweredCivic
May 3, 2003 10:43 PM
96grnaccord
May 10, 2002 01:55 PM
