Aluminum Welds Pitted
Old Jan 7, 2016 | 04:50 PM
AM_H2B's Avatar
Default Aluminum Welds Pitted
I'm welding aluminum and instead of getting a smooth bead, the bead has a slight rough texture. I have my gas turned up to 25 and I'm using a gas lense. I always clean the metal before welding as well. I wanted to see if anyone has input on what's going on Thanks!
<a href="http://www.liveimagegallery.com/Personal-Photos/Welding/n-tq5CFr/i-m4pNZHN/A"><img src="http://www.liveimagegallery.com/photos/i-m4pNZHN/0/L/i-m4pNZHN-L.jpg" alt=""></a>
Old Jan 7, 2016 | 04:59 PM
turbohatch96y7's Avatar
Default Re: Aluminum Welds Pitted
Have you tried lowering the cfm?
It may be cooling the puddle too much
Old Jan 7, 2016 | 05:45 PM
hahaha38's Avatar
You are letting off the peddle to fast at the end of your weld.
Old Jan 7, 2016 | 09:09 PM
AM_H2B's Avatar
I'll try that out tomorrow.
Old Jan 7, 2016 | 09:10 PM
AM_H2B's Avatar
Yeah, I know. The dimple creates a cracking point, right?
Old Jan 8, 2016 | 07:21 AM
1sick4g63's Avatar
It's due to overheating the material with using 4043 filler wire.
Generally your first pass will look good and after that they will look like this unless you let it cool.
Or switch to a 5356 filler and you won't have this issue
4drsedaneg
Welding / Fabrication
19
Jun 20, 2011 08:52 AM
1 2 NV
51
Jan 6, 2007 08:08 PM
turbo gli
Mar 15, 2005 09:03 PM
hunghimself
17
Nov 21, 2004 06:56 AM
forced00si
10
Aug 13, 2004 04:09 PM
