exhaust clearance issue with ITR rear sway
i have custom piping on my hatch (6 gen) and i know the ITR rear sway bar kinda angles down right after the mount on the subframe. by looking at it and from pics of the bar, it looks like the bar wont clear my piping. i know a lot of you guys out there with the rear ITR bar have exhausts, so which ones are compatible with the ITR rear sway? also, anyone have pics of the ITR sway and the space needed to clear the exhaust components? ive only seen pics of the sway bar on the driver side and would like to see some on the exhaust side. thanks all!
you sure? so NO ONE has an aftermarket exhaust AND a ITR rear sway bar? what sway bar will work with an aftermarket exhaust then?
Can an ITR cat back exhaust fit on a 6th gen EK hatch? my friend has a teg with ITR cat back and he has a rear ITR sway bar. If it wont fit, how do you make it fit? i assume you would not want to cut up the rear section of all the exhaust piping by the muffler. also, what is the piping size of the ITR exhaust? thanks
itr exhaust is 2.25''. the muffler is chambered.
although i am not 110% certain, i think the axleback section will fit on your car. it would be best to confirm this with a search.
GripFactoR
May 19, 2003 05:12 PM
