need help TB coolant lines
Old Jan 6, 2016 | 12:33 AM
sniper8898's Avatar
Default need help TB coolant lines
For the life of me where does the brass coolant line go from the tb to where? I know the silver one goes to my idle air control valve. I'm having a dumb moment any help is appreciated. I have a b20b with a gsr head.
Old Jan 6, 2016 | 10:41 AM
GreatWave's Avatar
10 Year Member
Default Re: need help TB coolant lines
It goes to the bottom of the water neck on the cylinder head
Old Jan 7, 2016 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This answer is going to depend on what thermostat housing and what cylinder head you happen to be using with your particular Frankenstein build. If there is not an open 5/16" coolant nipple on the thermostat housing, look to the upper radiator hose neck on the passenger side of the cylinder head. IF there is not a 5/16" coolant nipple/barb there, there WILL be a boss where you can drill a hole (1/8" NPT thread) and install a 5/16" hose barb in the hole... connect a hose between the T/B fitting and the upper radiator fitting.
zx92027xz
19
Jan 15, 2014 04:36 AM
Bwhit12
Jul 15, 2011 09:32 AM
quik sol
Jan 18, 2008 01:33 AM
JDM00SI
Jan 8, 2007 09:06 AM
B18C_eg
Aug 25, 2004 05:39 PM
