Car wont start when warm
Old Jan 3, 2016 | 03:50 PM
Dtmk69's Avatar
Default Car wont start when warm
Hey guys I have a 95 civic d15z1 it starts perfect when its cold but it does not start when it's warm I'm tried ignition coil and did nothing and today I unpluged the water temp sensor and it ran ok died twice but started right up and was sounding like it was missing could that be my problem or is it more in the dizzy or relay??
Old Jan 3, 2016 | 03:59 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Car wont start when warm
Is the CEL on? Does it work? Is this an original VX, or a swap? Check the spark color when the car is refusing to start.
Old Jan 3, 2016 | 06:52 PM
Former User's Avatar
Ohm test the ECT sensor.
Also try unplugging the O2 sensor.
Old Jan 4, 2016 | 08:33 PM
that_boy_sammy's Avatar
Check your timing, fuel, spark. Most likely timing is off some teeth if it runs when cold and like *** at op temp, or sputters and dies.
Old Jan 5, 2016 | 01:35 AM
delsolintegra's Avatar
Engine coolant temp sensor. They fail at about the 20 year mark.
about $25.
Old Jan 5, 2016 | 10:27 AM
jooky5's Avatar
my dizzy started failing on me and it would studder / shake the whole car. Finally failed and left me stranded on the side of the road.
Also check the main relay
aznjay510
Apr 29, 2019 08:13 AM
HondaStufff
24
Jan 17, 2019 01:19 PM
Apple395
May 16, 2014 09:17 PM
GSRdriver1104
Jan 22, 2008 09:58 AM
barbourjay
Feb 24, 2007 01:44 PM
