Power steering delete question
Hey guys. I have a 94 eg. I did the power steering loop. And added a breather. how do I add more fluid? I read to do it though the breather valve but the Fluid just sits there and doesn't go down the hose. Question is, how do I add more fluid
Well, for starters, what makes you think you need to add more fluid? After you loop the system, you should just have barely enough fluid in there to keep it lubricated - you don't need it completely filled. That being said, check your lines for kinks, and try moving the steering wheel lock to lock. And then drain out all that extra fluid you added when you didn't need to.
magic hat #9
Jul 16, 2003 08:00 PM
