92 accord fuel tank
Old Jan 3, 2016 | 02:49 PM
tim73's Avatar
Default 92 accord fuel tank
On my 97, the tank has a plastic cover over it. Is the 92 the same? Also does the 92 have a drain plug? Need to get rid of some bad gas. Thanks!
Old Jan 4, 2016 | 05:57 AM
masospaghetti's Avatar
Default Re: 92 accord fuel tank
I just drained my 92 tank. There is a plug on the bottom on the driver's side (I think its a 17mm bolt). There's a small plastic cover over the fuel lines but the drain bolt should be accessible without removing anything.
Old Jan 4, 2016 | 07:06 AM
tim73's Avatar
I put in some HEET last night...gonna see what if thything that does for me. If nothing...then ill drain the fuel. Thanks!
Old Jan 5, 2016 | 06:55 AM
Using gas is always the easiest way to get rid of it, assuming it's not totally stale. You could always mix it in small quantities with fresh gas until its gone.
Tgraves3
Nov 18, 2015 05:13 PM
moparguy
Aug 26, 2015 04:24 PM
civicfan14
Jan 12, 2011 06:37 PM
-NA-H22A
Jun 16, 2006 09:53 PM
shortyz
Mar 21, 2003 10:51 AM
