AEM boost by gear with Greddy solenoid
Old Jan 1, 2016 | 06:41 AM
m0sad's Avatar
Default AEM boost by gear with Greddy solenoid [solved]
Hello you guys,
yes, I've searched it [=
i have the greddy solenoid from the profec B spec 2.
gave it 12V and hooked it to the boost output in the ems c10.
manage to make it work, but it is not working 100%.
i tune it via VSS. and when i put it on 16psi it gives me 20psi.
also the solenoid it knocking like a @!#$%$ and while maintaining full throttle the boost is playing like i did the line in the ems like this:
*----_----_----_----_----_---- *
frequency is 31hz
need help [=
thx
Old Jan 1, 2016 | 07:06 AM
turbohatch96y7's Avatar
Show some of your tables.
Show the main table for the boost control
Old Jan 1, 2016 | 11:57 AM
m0sad's Avatar
Default Re: AEM boost by gear with Greddy solenoid
this is pretty much it
direct link to image: http://i66.tinypic.com/2yvq4nb.jpg
thx for the help [=
Old Jan 1, 2016 | 02:52 PM
Bye
Old Jan 1, 2016 | 02:54 PM
Ive never used v1 this is coming from my experience of the v2
3.2 firmware
It may be different but i doubt it.
Old Jan 1, 2016 | 02:55 PM
The clicking you are hearing is because the ebc is trying to target 5psi at o mph
Look at the table and itll make sense
Old Jan 2, 2016 | 12:05 AM
m0sad's Avatar
Thx man i will check that.
I can go over 20psi easely (:
My problem is that the car doesn't stay in boost.. its playing like i explained earlier..
I will give it a try and get back to u.
Thx man
Old Jan 2, 2016 | 10:22 AM
Bye
Old Jan 2, 2016 | 11:13 AM
Flr Power's Avatar
OP, Can you post the VSS boost tables? Like that...
Old Jan 8, 2016 | 10:15 AM
m0sad's Avatar
sorry, did not had the time to test the car, it's raining like a @#$#@ here [=
i will get it done soon.
Old Jan 13, 2016 | 09:51 AM
accorse07's Avatar
Not sure where you have gotten with this but if you are on a Series 1 AEM ECU...there is no Boost by Gear.
Old Jan 15, 2016 | 06:23 AM
m0sad's Avatar
here is my VSS map
my O2 is not connected and is disabled in the ems.
it seems that the boost always goes back to the wastgate spring (10psi)
friend of mine told me it my-be regards with somthing called open/close loop
im really lost lol
"boost by VSS" ok ?
Old Jan 15, 2016 | 03:49 PM
accorse07's Avatar
Your boost WG Duty table is 0% which means you are not commanding your solenoid to add any additional Duty in order for you to achieve more than waste gate spring pressure.
Old Jan 15, 2016 | 04:11 PM
Flr Power's Avatar
Yes a lot of cleanup is needed. First set the entire Boost WG Duty table to 50% from 2.68psi up breakpoint, uncheck Boost from Load, uncheck for now ''Boost FB P+I'' and the Boost Error Duty table has to be done in a more aggressive way.
Old Jan 17, 2016 | 01:43 AM
m0sad's Avatar
I will try it.
Thx for your patience (:
How do fill about this guide:
https://www.google.co.il/url?sa=t&source=web&rct=j&url=http://farnorthracing.com/DG_Guide_to_AEM_boost_control.pdf&ved=0ahUKEwiQ2db 307DKAhXB1RoKHdmHDqgQFggaMAA&usg=AFQjCNENifLXx5MBl UuO21V64x1LmFMadg&sig2=VBOBPCkYnpaBGqeuaqmaeQ
Any good ?
Old Jan 17, 2016 | 08:13 AM
Flr Power's Avatar
The first 7 steps are good but after that it shows he does not fully master boost control settings.
Anyways, I don't use Boost comp table. I prefer using the Boost WG Bas Duty Map with Boost Error Duty table for corrections.
If you set those tables correctly you will have very stable boost even with an 8psi spring boosting to 30psi.
Old Jan 17, 2016 | 10:51 AM
m0sad's Avatar
I will test the car again later this week and update here.
Thx !
Old Jan 17, 2016 | 11:07 AM
Originally Posted by turbohatch96y7
Looks like youre in v1
The main table should have the values to reach the psi youre after.
For example 10 psi column should have 30
Then 20 psi something like 60
Then you set your vss table. The vss table uses that main table to target psi based off speed
Question
Is the boost hitting a constant psi? Is it over boosting?
Can it make more than 20 psi?
Mentioned the same thing here
Old Jan 17, 2016 | 11:22 AM
m0sad's Avatar
Yesterday i just started from the beginning.
This time i used the "boost controller wizard " (noobe i know )
But it worked! No more creeping boost !
BUT NOW... lol the vss dont work, and now after I've done all that i can understand what you guys meen when ur talking about the main wg table..
So i will try again this week (:
Old Jan 28, 2016 | 12:08 AM
m0sad's Avatar
OK,
reset the whole boost set up and started over.
because im not gonna go over 30PSi (or close to that) i set the whole 'Boost WG Base Duty' map to 50.
now for to tune the boost to my specific target i needed to use the 'Boost Target Comp' table.
i set the boost in the vss map to 10psi
and in the 'Boost Target Comp' set it to -27%
then i set up the high boost 20psi in the vss map to about -23%
i set the 'Boost Target Comp' so the spikes i made from -27 to -23 would be straight.
every thing is working fine, the mistake i did when my boost was not consistent was that i marked the 'boost FB on Error' to be active [=
all you need to 'check' is:
1. Boost W/G Output
2. Boost WG FeedBack
3. Boost FB VSS
now my vss is not accurate :\ anyone know how to adjust the vss?
Old Jan 28, 2016 | 06:04 AM
Flr Power's Avatar
There are many ways to adjust the boost control strategy. The way you are doing will cause boost fluctuations when temperature changes...
Change ''VSS Calibration'' parameter to match your true speed with the EMS.
Old Jan 28, 2016 | 06:18 AM
m0sad's Avatar
the boost always changes when there is major Temp change, it's not bothering me [=
and about the vss, i will try it and will update - thx man [=
m0sad
Sep 21, 2017 06:13 AM
wrx-killer-Sti-eater
Aug 8, 2012 08:19 AM
turbo-2nr
Mar 3, 2010 09:01 AM
civic-r11
Jul 21, 2008 10:32 AM
austrian type-R
May 25, 2002 11:29 AM
