Mounts
Old Dec 30, 2015 | 08:41 AM
jbhoops's Avatar
Default Mounts
What is the best brand for tranny and motor mounts.90 civic hatch stock eng
Stock or aftermarket?
Old Dec 30, 2015 | 01:52 PM
acmoc's Avatar
Default Re: Mounts
Your current mounts, filled with polyurethane.
Old Dec 31, 2015 | 07:14 AM
jonGSR's Avatar
Default Re: Mounts
If your stock, I'd just get some OEM replacement mounts to avoid having the car vibrate with urethane filled stock mounts. Unless you're making a ton of power the urethane isn't necessary. If you're doing a lot of launches on a stock motor, you'll still wear out the stock mounts quick.
Old Dec 31, 2015 | 03:26 PM
jbhoops's Avatar
Default Re: Mounts
Thanks guys. I just thought there might be some hard rubber alternatives
Old Dec 31, 2015 | 10:31 PM
acmoc's Avatar
Default Re: Mounts
justt fill them with urethane from home depot
Do one then two, then if you still want stiffer, do three, then four
Start with the one furthest from the cabin.
They'll last forever if done right
poseghatch
13
May 14, 2013 11:43 AM
dcb16
May 18, 2005 07:11 AM
vangc6780
May 1, 2005 10:14 PM
crxgator
Dec 30, 2003 08:53 PM
