Cylinders flooded with fuel
90 ef si b16
Wanted to see if anyone has had this issue and would like to give me some advise.
Engine is flooded with fuel #2 only. Have spark , good compression, no cel codes. Car turns on but real hesitant and spits good amount of fuel through exhaust. No power at all. Timing is good, car ran fine just happens from one day to another
It's fuel. Not burning coolant at all. I'm guessing it has to do with wiring but just checking to see if anyone has had this issue before. I've swapped out injectors and same problem with the same cylinder. Stuck open only at plug #2
Your distributor is not retard? You have correct heat range plugs? Correct fuel injectors rating for ur build? Correct fuel pressure? Correct tune for ur car? No missing injectors gaskets?
some things i can think off
Found out issue. After market fuel pressure regulator(aem), opened it up and they have a rubber gasket in there. Gasket had a minor tear which was letting gas through the vacuum side of the regulator. Which lead to the intake and so on out the exhaust
This is because of loosening of valve cover gaskets . On that engine, the spark plug tubes go down through the top of the valve cover. The tubes have tube seals that come with the valve cover gasket set. This is not a big issue . The valve cover gasket is easy to change. Also, valve cover and cylinder head cover are interchangeable terms for the top cover of the engine.
cobrahandler
May 19, 2004 12:54 PM
