Honda CR-V & Element 2WD & 4WD Element & CR-V
Honda Element Limp mode help please
Old Dec 28, 2015 | 12:06 PM
Honda713's Avatar
Default Honda Element Limp mode help please
Hello all, we have a 04 Hond Element 134k, I had to replace Starter, 40 days ago, and a week after we had a cup of water removed from fuel tank. 3 weeks later it had been running perfect entire time. and no after it drives for over 1 hour it goes into limp mode. Wont rev past 2000 rpms. No codes or engine lights thrown. Dealer reset ecm or put it into relearn mode and it still does it. Dealer is stumped. So are we. If driven Under 65 or under an hour it doesn't do it. Once you hit an hour or so of over 65 and then slow down it will go into it unless turned off for a while, then it may take another hour or more to go back into it. Really stumped, any ideas??
Old Dec 28, 2015 | 12:44 PM
MyGreenHonda's Avatar
Default Re: Honda Element Limp mode help please
Are you gettign any check engine light ? What are the codes ?
Old Dec 28, 2015 | 01:26 PM
UK-Kev's Avatar
You may have low fuel pressure – Do you still have the normal air rush when you open the filler cap.
Also you need to check for ODB code when the fault is present and the engine running in limp mode.
Kev
Old Dec 28, 2015 | 01:36 PM
Honda713's Avatar
There is No codes, No check engine light, Dealer had computer plugged in for several hours while running it, and no codes were recorded, they did say the fuel pump was being shutting down or limited by the ecu. it seems to happen mainly when really hot (engine temp is in the middle) after running over an hour.
Old Dec 29, 2015 | 07:45 PM
EJ8_Man's Avatar
Your car is not in "limp mode" without a check engine light present. You could be experiencing hesitation because your fuel is still contaminated with water. Or your fuel pressure is low. Is your check engine light actually working? I.e is the bulb burnt out? Do you know how your gas was contaminated with water? Do you know if all the water was removed? There are additives you can add to your tank to help remove water chemically (Google HEET). You could also drain your tank and start with fresh gas.
If your fuel is not contaminated, check you fuel pressure.
I would personally plug in an obd2 scanner yourself and see what your ecu state is. Look for error codes and pending codes. You can rent a scanner from many auto stores, or buy one.
Old Dec 30, 2015 | 02:59 AM
Honda713's Avatar
Fuel tank was completely drained, sock was not clogged. 2 treatments of Heet had been used. Vehicle suffers no rough running or acceleration misses etc. When it goes into "limp mode" it will not rev past 2000 rpms exactly. even in idle. still runs smooth. just no rev past 2k. Codes were initialy checked via Autozone, no codes, Dealer drove for Hours, after day 2 they got it to replicate the issue. said the ecu was limiting the fuel pump when it did its "limp mode" thing, still no codes collected and this was from the Honda ""(drive along, not sure proper term) computer hooked up. They ran it for 3 hours yester day and it wont do it, needs to be on a longer highway trip.
My understanding is if it was a faulty pump it either works or it doesn't. not one of these "it works sometimes" things.
Thoughts?
Realbadman
Feb 25, 2018 06:28 PM
AllOutBeard
Apr 21, 2017 05:42 AM
Jim Linden
Feb 24, 2015 09:58 AM
jester4190
Jan 9, 2008 04:20 PM
