Swap Accord trans to Odyssey?
Background:
We have a 1998 V6 Accord EX with auto trans. Just rebuilt the trans and extensive work on motor. Car just kissed a tree and has damage to right rear quarter that makes it uneconomical to repair. Have access to four Odyssey's of 1999, 2000, and 2001 vintage all with V6 and auto trans. All have failed trans but body, and other stuff working well including engine.
Questions:
Can Accord trans be swapped into Odyssey? If so which years? Any other years than those mentioned?
If so, would it be better to keep Accord eng/trans together and do a complete swap? We know the Accord engine, don't know the others so much.
Thanks for help.
Accord vin is 1HGCG165WA075209
Don't have Odysseys' vins
Questions:
Thanks for help.
They are of the same family and same transmission.
Found these gear ratios on the web, no idea if they are true. If so the Ody will have slightly degraded economy, with better acceleration.
'00 Ody V6
Final Drive Axle Ratio (:1) 3.941(2.30 in OD)
Fourth Gear Ratio (:1) 0.583
Third Gear Ratio (:1) 0.884
Second Gear Ratio (:1) 1.374
First Gear Ratio (:1) 2.428
Reverse Ratio (:1) 1.846
'00 Accord EX V6
Final Drive Axle Ratio (:1) 4.200(2.56 in OD)
Fourth Gear Ratio (:1) 0.609
Third Gear Ratio (:1) 0.947
Second Gear Ratio (:1) 1.503
First Gear Ratio (:1) 2.534
'00 Ody V6
'00 Accord EX V6
jfboy
Dec 6, 2019 09:43 AM
