Hasport mount install
Old Dec 24, 2015 | 10:31 PM
PeterVSays's Avatar
Default Hasport mount install
I bought some hasport 70a mounts, it came with three mounts and about 4 extra bolts. The rear mount fits fine, maybe a little high, but the driver side does not sit flush on the engine. I've talked to Bitanga about this and he said I might have to change the studs, I've also talked to Chase and he recommended me to contact hasport or drill the bottom side a little wider. Any input would be great. Thanks.
Old Dec 25, 2015 | 06:35 AM
Rus1an's Avatar
Default Re: Hasport mount install
Are you sure these are real Hasport mounts? There has been some fakes going around. Not sure exactly how to spot them.
Old Dec 25, 2015 | 07:10 AM
PeterVSays's Avatar
Bought them straight from hasport themselves.
Old Dec 25, 2015 | 08:33 AM
DC4KiD's Avatar
Do you have a 2-bolt post mount, or 3-bolt? The bigger studs are usually found on the 2-bolt post mounts.
Old Dec 25, 2015 | 09:37 AM
PeterVSays's Avatar
It came with 5 bolts. And the more I thought about what Bitanga said, I might have to knock out my old studs on the engine and use the hasport bolts.
Old Dec 25, 2015 | 12:03 PM
VegaS10's Avatar
Remove the oem studs in the engine bracket and use the has port studs to mount the new mount to the bracket.
Old Dec 25, 2015 | 05:27 PM
PeterVSays's Avatar
Yeah I figured that was the case. How'd you remove the old studs? I really don't wanna use my oem mount because it's dry rotted and my hasports are 70a.
Old Dec 25, 2015 | 05:56 PM
PeterVSays's Avatar
Ignore this comment, my dumbass figured out how to remove them.
acmoc
Mar 29, 2017 05:36 PM
Con
Dec 9, 2010 11:58 PM
Nova_Dust
Mar 14, 2008 04:40 PM
dso
Dec 2, 2004 05:15 PM
solman74
Sep 21, 2003 11:52 AM
