MAIN RELAY not working. Ignition switch?
Old Dec 23, 2015 | 05:50 AM
Goobergobbler's Avatar
Default MAIN RELAY not working. Ignition switch?
I bought a 97 civic and swapped a b series in it and wired some gauges (guessing this was where I messed up) tried to start it and wasn't getting power to anything. I jumped the relay and the pump kicked on so I replaced the main relay. Still nothing. Then I found out there was no power to pin 5 on the relay and my dash lights were not coming on. So naturally I replaced the ignition switch now I have power to pin 5 but the relay still isn't clicking at all and the dash lights aren't coming on either and nowwwww my gauges are either half way lighting up or just flickering and cutting off. I'm at a loss
Old Dec 23, 2015 | 10:31 PM
Default Re: MAIN RELAY not working. Ignition switch?
Bump
Old Dec 24, 2015 | 08:15 AM
Former User's Avatar
Sounds like dash fuse 13 is blown.
Old Dec 25, 2015 | 07:00 PM
It's good. Replaced it with a new one to rule it out.
Old Dec 25, 2015 | 07:53 PM
Is there now battery voltage at pin 5?
Old Dec 26, 2015 | 09:41 AM
Yes. I checked pin 1 and 5 by grounding to pin 2 and both had voltage
Old Dec 26, 2015 | 11:43 AM
eghatch9295's Avatar
Stancetard Hate Monger
sounds like a ground issue to me.
Old Dec 26, 2015 | 02:37 PM
^Makes no sense. Main relay pin 2 connects to dash fuse 31.
Old Dec 27, 2015 | 06:44 AM
The thread I read for troubleshooting said to do that. There was continuity. What do you suggest
Old Dec 27, 2015 | 07:18 AM
Unplug main relay.
Turn key to ON(II).
In connector, jump pin 7 to pin 4. Does pump run?
In connector, jump pin 5 to pin 4. Does pump run?
Old Dec 27, 2015 | 09:51 AM
Ok I'll get back to you as soon as I get back around the car
Old Dec 28, 2015 | 03:34 PM
My Clip doesn't look like that.
Old Dec 28, 2015 | 05:33 PM
civic402lx's Avatar
Flip it over. Look at it from the wires side. Not the the terminal side, like your photo..
Old Dec 28, 2015 | 06:02 PM
Match the wire colors.
Old Jan 1, 2016 | 11:03 AM
Ok so I was having a ground issue but I fixed it and here's what's going on now. I turn the key to on-1 my gauges come on. Turn the key to on-2 gauges shut off, brake light in cluster turns on, still no clicks from relay but when I jumped it the pump kicked on both times, turn the key to start and my radiator fan kicked on the first few times then it didn't do anything for a minute then I plugged the relay back in and it clicked but only when I turned the key to start.
Old Jan 1, 2016 | 11:44 AM
Details?
Ohm test the ignition switch. See FAQs sticky.
Old Jan 1, 2016 | 01:58 PM
It was the ground cable from battery to chassis. The terminal had wiggled loose from the terminal. I don't have a way to ohm test the ignition switch but I have another switch I will run the tests with again tomorrow.
Old Jan 1, 2016 | 02:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
You can test for continuity, but you don't have a way to ohm test? Uh...what?
Old Jan 1, 2016 | 02:08 PM
You got it.. I don't own a multimeter and I used a friends test light.
Old Jan 1, 2016 | 02:17 PM
NotARaCist's Avatar
Then...you never actually tested for continuity. Gotcha. Go buy a multimeter. They're like, $10 at Walmart. You can't actually do the proper tests to diagnose your problem without one.
Old Jan 1, 2016 | 02:32 PM
Haha. Ok I'll grab one on my way to the car tomorrow. How do I correctly ohm test the switch.
Old Jan 1, 2016 | 02:34 PM
Originally Posted by RonJ
See FAQs sticky.
Old Jan 1, 2016 | 08:02 PM
i win again!!!1!!!1
Old Jan 8, 2016 | 05:41 AM
Ok so I tested both the switches I had and they both were showing resistance over .5-.7 they never really settled, kinda bounced all over the place. So both are bad correct? I will order a new one today
Old Jan 8, 2016 | 05:47 AM
Ok so I tested both the switches I had and they both were showing resistance over .5-.7 they never really settled, kinda bounced all over the place. So both are bad correct? I ***** order a new one today
