Starting Issue
My 1996 Honda Civic DX won't start. I changed my distributor, battery and spark plugs not too long ago. When I push my clutch in and turn the key I can hear the fuel pump come on but I don't hear the car try to start up at all. I had to pop my clutch to get home. I checked my fuse box, and everything is in order. What could it be? Bad Crank Sensor or what? I think my starter isn't receiving any power, but I could be wrong.
There's a small rubber bit on the top of your clutch pedal that tells your car you have your foot on the flutch. It's pretty common for that small rubber bit to fall off or break. Check to make sure it's still there.
CiViC_SOHC
May 29, 2007 06:31 PM
