How/where is my ignition coil
Old Nov 6, 2002 | 09:58 AM
Ideal's Avatar
Default How/where is my ignition coil
I think my car isnt starting due to my stock ignition coil, im not sure where it is, or how to check it.
Old Nov 6, 2002 | 10:01 AM
Stew Pidasso's Avatar
Default Re: How/where is my ignition coil (Ideal)
I believe it's under your distributor cap. It is more likely that the igniter is bad. Auto parts stores like Auto Zone can test them. Maybe pull a plug wire off of the engine and hold it close to ground while having someone crank the engine. If there is no spark then you know that is the problem.
Old Nov 6, 2002 | 10:04 AM
Chiovnidca's Avatar
What year?
Old Nov 6, 2002 | 10:07 AM
Default Re: How/where is my ignition coil (Chiovnidca)
What year?
My Accord:93 Honda Accord EX Edition: 4th Generation
Old Nov 6, 2002 | 10:10 AM
Chiovnidca's Avatar
Default Re: How/where is my ignition coil (Stew Pidasso)
Right rear corner of the valve cover. Just follow the coil wire from the distributor cap.
Old Nov 6, 2002 | 10:58 AM
Ideal's Avatar
can someone post a hondaautomive pice and like kinda draw it or something, im on a college campus, do i kneed any tools to get to it?
how much do ignitors and coils run?
-Jon
Old Nov 6, 2002 | 11:33 AM
#7 is the igniter
#3 is your coil
Taken from http://www.hondaautomotiveparts.com/...RD-+SPARK+PLUG
And
http://www.hondaautomotiveparts.com/...IBUTOR+%282%29
Respectively
[Modified by Stew Pidasso, 3:40 PM 11/6/2002]
Old Nov 6, 2002 | 11:49 AM
Ideal's Avatar
thanks for pointing those out, helped me out alot, so what kinda of tools am i gonna need to do this? scale of 1-10 how hard? or should I just take it to any mechanic?
Old Nov 6, 2002 | 11:52 AM
If your just going to replace the coil and/or igniter it is pretty easy. Kinda like changing a valve cover gasket or something on that level. A screwdriver and some sockets from 8mm-14mm should be enough.
Old Nov 6, 2002 | 12:44 PM
Chiovnidca's Avatar
It's a little more complicated if he want to be sure what the problem is. It can get expensive just throwing parts at it.
Old Nov 6, 2002 | 12:47 PM
GimpyAccord's Avatar
Its rare for one of the external coilpacks to go bad from my experience. I would get a test light and make sure you're getting +12V to the igniter. Have you tried seeing if you even have a spark as suggested earlier? I carry a spare igniter in my toolbox just for occasions like this
Old Nov 6, 2002 | 12:51 PM
RotaryBzzz's Avatar
Default Re: How/where is my ignition coil (GimpyAccord)
In my old VW, I'd always carry a spare alternator for times like this. lol
xero_xero
Jan 13, 2014 04:35 PM
tichal2008
Nov 10, 2009 09:20 PM
Horsequick
May 27, 2007 02:04 PM
WeaponR
Apr 4, 2004 09:44 PM
Wiseguy619
Oct 19, 2003 12:25 PM
