Distributor swap on 1997 crv
I have a 1997 crv. I was in process of converting to an external when I found distributor was shot. Can I just swap distributors because I already have an external coil.
WHY are you swapping to an external coil? It's not needed for under 700hp.
You can directly swap any b18b or b20b/z dizzy or you can use a b series vtec dizzy if you chop one of the legs off.
