Where should I cut? (Pictures inside)
Old Dec 16, 2015 | 02:46 PM
averyvm's Avatar
Default Where should I cut? (Pictures inside)
Hey Guys
Ive got some rust on my hatch that I'm trying to fix
Where do you think I should cut on the salvage piece.
salvage piece
I've drawn a line with a silver sharpie of where I think I should cut.
Here's the top side.
Here's the under side.
What I'm worried about is, I'm cutting through a bunch of layers of metal that I won't be able to weld back together.
Here I show 4 layers. When this back together I will only be able to weld the outer most layers.
Layers
I've also included some pictures of the car, the area of which I'm trying to replace.
Outside
inside passenger side
inside driver side
Old Dec 20, 2015 | 03:16 PM
Hidenplanvew's Avatar
Default Re: Where should I cut? (Pictures inside)
take that apart layer by layer and you will have your idea of where you need to cut.
Its better to replace the whole parts then just fragments if you can.
Eyger
Paint and Body
Mar 11, 2009 02:58 PM
Blake8418
Welding / Fabrication
Nov 28, 2008 05:43 PM
K20me
Jan 16, 2007 05:11 AM
K20Z1320
10
Nov 18, 2006 08:53 PM
