500$ rust repair?
Old Dec 15, 2015 | 02:22 PM
Bendito's Avatar
Default 500$ rust repair?
So I just bought this car & would like to take care of these rust spots before they spread. One is right rear quarter panel & the other on driver side main body. Just got quoted 500 at the shop which seems high but heres my real question.. Does the metal need to be cut out & fabricated on that left side, rust doesn't look to have gone all the way through. Right side for sure, as I can see its flaking off but the shop said cut them both out to be safe. Just need some opinions before I drop 5 bills tomorrow. Thanks.
Old Dec 20, 2015 | 03:12 PM
Hidenplanvew's Avatar
Default Re: 500$ rust repair?
yup 500 for rust repair isn't bad at all.. most shops are 65-75 an hour for repairs not including paint. yours are rusting from the inside out, that's why its bubbling up like that.
Take those stupid edge protectors out from your wheel wells, that's why you have rust where you do.
Old Dec 21, 2015 | 06:48 AM
kp's Avatar
kp
$500 sounds cheap for that work, at that price I would expect corners to be cut. Anytime you see rust through the surface like that you can usually assume you're only seeing 1/3 of it. The area of work will end up being much larger than the rust you can see.
Old Dec 21, 2015 | 07:42 PM
I guarantee there will be "hidden" cost when they start cutting or it will come back fairly quickly
[Edil]clyde
Paint and Body
10
Apr 3, 2009 01:54 PM
CRX MASE
10
Jul 13, 2006 11:20 AM
NXLude
Oct 11, 2005 05:21 PM
GT_Alpha
May 10, 2005 01:25 PM
mdarnell
Apr 18, 2005 04:47 AM
