Garage Sale! B, D parts, used, new, OE, all kinds will keep updated
I will keep this thread updated as I sort through everything! If interested in anything please PM me and if you need more pics let me know!
I will ship anywhere in USA, small stuff 1st class, larger stuff generally priority mail. Will discount prices if multiple items are wanted and combine shipping!
Prices do NOT include shipping, let me know your ZIP and what you want for a quote! I do not charge extra for PayPal fees, I eat 'em for ya. Please no lowball offers, but prices may be slightly negotiable on some items and I will discount prices if multiple prices are wanted along with combine shipping. Payment via PayPal, mine is verified and yours should be to.
Onward with the parts! Check back often, I will update!
<b>PR3 B-series A/C bracket with idler pulley from 90-93 Integra B18A1 $20</b>
*B-series most, AC compressor bolts onto this
<img src="http://i67.tinypic.com/142by4j.jpg" alt="integra ac compressor bracket">
<b>P3F B-series oilpan $50</b>
*Fits B-series without crank girdle including B16, B18A/B
<img src="http://i67.tinypic.com/257pv8g.jpg" alt="B series oil pan">
<b>Cam gears $10 each</b>
*D16y8 x 2, B-series "PR3" x 2, D16Z6/D15 PM3B x 1
<img src="http://i66.tinypic.com/255ugpf.jpg" alt="d series b series camshaft gears">
<b>B18A1 valvecovers $30 each</b>
*All off B18A1s, fit B18A/B and B20, need strip, clean paint
<img src="http://i64.tinypic.com/e7axc4.jpg" alt="B18a1 valve cover red">
<img src="http://i64.tinypic.com/zv1zwj.jpg" alt="B18a1 valve cover black 2">
<b>B18A1 intake manifold with throttle body and fuel rail $50</b>
*Includes throttlebody w/ TPS, fuel rail, as shown, no IACV or anything else not shown
<img src="http://i63.tinypic.com/2cgna12.jpg" alt="b18a1 ls intake manifold throttle body fuel rail">
<b>D16Y automatic transmission flexplate with bolts and spacer $30</b>
*Removed from 99 Civic EX D16Y8 automatic transmission, should fit all D16Y and maybe more
<img src="http://i65.tinypic.com/1zmf48p.jpg" alt="civic d16y automatic transmission flexplate spacer bolts">
<b>B18A1 pistons and rods x 3 $30</b>
*From 91 B18A1 engine, good if you need spare or replacement LS rods
<img src="http://i68.tinypic.com/2jib2d.jpg" alt="LS B18a1 pistons connecting rods">
<b>Misc. parts 1: EVAP purge valves from 96-00 civic $10ea, Ford T3 thunderbird turbo inlet adapter $10,
OBD1 injector plugs $15, E12-303 ignitor $20, Golden eagle camseal (needs orings) $10, ECT sensor $5,
95 Civic LX VSS vehicle speed sensor (fits others) $30</b>
<img src="http://i67.tinypic.com/33fdy03.jpg" alt="purge valve ect cam seal vss ignitor injector plugs">
<b>OBD0 ECU plugs $15, OBD1 ECU plugs $15, MAP plug $5, TPS plug $5, 3-wire IACV plug $5,
2-wire IACV plug $5, VSS speed sensor plug $10, 4-wire O2 female or male plugs $5</b>
*Misc ecu and sensor plugs
<img src="http://i68.tinypic.com/2cmq5pd.jpg" alt="ecu plugs obd0 obd1 iacv map vss o2 sensor">
<b>Stock MAP (throttle body mounted) $10, Motorolla/Freescale 4bar MAP $10</b>
*MAP sensors and ecu part
<img src="http://i66.tinypic.com/okwk5h.jpg" alt="stock map sensor 4bar map sensor sta460c injector driver">
<b>New OEM Honda parts in package - very new fresh parts, stored inside $varies</b>
*B-series valve cover stud x 2 (90014-PR3-000) $5 each
*OE Thermostat and gasket (19301-PAA-306) $18
*OEM Cigarette lighter plug hole cover (39623-S10-A01) $3
*Turn signal socket 94-01 Integra (33302-ST7-A01) $10
*B-series camshaft bolt (90031-PV0-305) $4
*94-02 Accord P0A valve cover gasket and tube seals (12341-P0A-000, 12342-RYE-004 x 4) $15
*Shifter repair spring accord automatic (54133-SDA-A81) $1
<img src="http://i66.tinypic.com/1zz0pwn.jpg" alt="new oem honda parts">
<b>New OEM Honda parts in package - still new unopened, dirty from years in garage $varies</b>
*Front grill screws for 96-00 civic and more (90126-SR4-000 x 5, 93903-423J0 x 4) $10 for all
*Axle seal for some civics, accords, crv and others check part number (91205-PL3-B01) $8
<img src="http://i63.tinypic.com/6r54e0.jpg" alt="new old stock oem honda parts">
<b>PICTURES PENDING:</b>
* 90-91 Integra PR4 ECU socketed $75
* 90-91 Accord TCM automatic trans computer REBUILT $100
* 90-93 Accord parts - complete intake manifold with injectors, IACV, throttle body etc, distributor, water pipe and thermostat housing, accessory brackets, flywheel with good clutch, exhaust manifold with one broken stud, crank pulley with bolt
...more to come soon!
Also have a 90-91 Accord transmission computer (rebuilt) and socketed OBD0 PR4 ecu That I will be posting soon after I get pictures!
PM if interested in anything!
Also have some Seadoo and 1g DSM parts (no BOV or injectors) if anyone is interested in those PM and I can tell you what I have.
