97 civic fuse box fire
Old Dec 12, 2015 | 04:35 PM
Killwhitneydead's Avatar
I drove it home from work and parked it in the driveway and walked inside. Ten minutes later the alarm was going off and it was burning up. The alarm has never went off. It almost sounded like it was turning the starter over. The fuse box and **** caught fire but I was able to put it out fairly quickly. This is a 97 automatic 1.5 non vtec. Can it be saved? I have another 97 civic same motor but manual trans. Could I swap the wires over and be able to drive the burned one again?
Old Dec 12, 2015 | 04:45 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 97 civic fuse box fire
sure, but good luck getting that smell out
Old Dec 12, 2015 | 04:47 PM
oneheadlight's Avatar
wow.. I gotta ask.. did you discover WHAT caused that fire?
Old Dec 12, 2015 | 06:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Can it be saved? Sure. Is it worth saving? Doubtful. Also, 1997 1.5L non-VTEC? There's some information you aren't telling us. That isn't how things work around here.
Old Dec 13, 2015 | 08:45 AM
stocker2shocker91's Avatar
I requested a short story for a title.
the smell is going to be your worst problem here. Who installed the alarm?
Old Dec 13, 2015 | 09:34 AM
tony_2018's Avatar
Fish Twig
You can find all the wiring you need from another donor of the same yr/make/model. GL with the smell.
Hope you find out what caused the fire, an alarm installation that was half-assed could've caused this.
Old Dec 14, 2015 | 05:54 PM
94EG8's Avatar
Seagull Management
You'll need a harness, actually multiple harnesses from another '96 - '98 automatic. DX/LX are the same, EX is unique to itself as is the HX.
To get the burnt smell out go to a place to does property restoration for fire/flood damage and see if they'll rent you a machine, we've done it at work a few times for fire damaged vehicles and works very well.
bseriescrxsi
Jan 5, 2015 05:36 PM
umar74
Honda Civic (2001 - 2005)
10
Sep 17, 2008 12:56 AM
sL1cK
Oct 27, 2005 07:34 PM
gritsak
Audio / Security / Video
Aug 25, 2005 11:04 AM
